Oscilloscope ac coupling......
Zeeus
Joined Apr 17, 2019
616
Hi...
Please see the attached image...I was watching signal source and signal at base of transistor
why is it that when I reduce vertical scaling the signals go down (below ground) I know I can adjust the knob to take it up but any other way??
Also..can you believe that the yellow waveform is the signal at base???? (truth)..Although Reducing base resistor brings the top part of the yellow waveform down
33k input at base with 2.2k at emitter...12v at collector and -12 through resistor to emitter
Ya’akov
Joined Jan 27, 2019
10,226
I dont understand
You have the scope in the photo set to trigger on runts. It is also set to DC coupling.
By the way, if you put a formatted USB drive into the scope, pressing the blue Print button will save a screen shot to the drive. This is a lot better than a photo.
Zeeus
Joined Apr 17, 2019
616
hmmm..seems you got this scope...
"You have the scope in the photo set to trigger on runts. It is also set to DC coupling"...Will try to fix in 20mins..so I remove trigger on runts...but like I said, i put ac coupling on both channels
Zeeus
Joined Apr 17, 2019
616
Hi..I changed it from trigger on runts to edge...The image did not really change...The signal should not go down right?
Ya’akov
Joined Jan 27, 2019
10,226
yeah right...should it not go from -300 to 300?
I am not the scope, it seems to believe that in reference to its ground, the signal is almost completely negative-going. It looks as it is has a tiny positive-going part. If you are sure you are AC coupled, then it seems your circuit is producing negative output referenced to 0V.
Zeeus
Joined Apr 17, 2019
616
lol..seems you know the scope more than I do...
Anyways, thanks...There are other interesting posts about AC coupling..will read
