I've been measuring the output of an old ramp generaton with an not so old oscilloscope.
As far as I know, AC coupling "removes" DC components of the signal measured so you only see transients, and the signal I measured had a pretty small DC component, so I tried to use this coupling to "remove it", but then I got what you can see in the pictures attached.
I read the manual so I know that its AC coupling doesn't work at frequencies lower than 20KHz, so I know now why it didn't work, but still curious, why did this happen? or what shall I interpret from this readings?
