Datasheet, datasheet, datasheetI need a 16 MHz crystal oscillator, square wave output. square and sine wave types exist, sellers don't mention which type their product is. How can I be sure I am buying square wave?
No datasheets offered on the sites I have been on. and no specifications. Wrong sites? Where would you go for this?Datasheet, datasheet, datasheet
You go to a reputable company that provides relevant design information.No datasheets offered on the sites I have been on. and no specifications. Wrong sites? Where would you go for this?
Presumably if you are dealing with surplus parts it is because you have the time and the equipment to sort the parts into two piles. One pile you intend to use for some useful purpose and the other pile you intend to bin. To buy surplus parts under any other conditions is to consider the seller a charity that you don't mind throwing money at for literally NOTHING in return.I sometimes source components from surplus suppliers who never provide the datasheet, but it's nearly always available from the manufacturer. Just keep in mind that if your buying surplus or from non-reputable suppliers your parts may not match their specs exactly. Components are usually rated to a certain specification with a designated % of tolerance. Surplus is sometimes components that measured closer to the extremes of that tolerance and wasn't suitable for production use.
Thanks, that was helpful.Crystal oscillator modules generally generate square wave output.
They will look similar to this:
https://www.futurlec.com/Crystals/OSC16000pr.shtml
