orCAD 9.2 installation issue in win8
mcgyvr
Joined Oct 15, 2009
5,394
Restart your computer and try to install again.
Have you also verified that you have sufficient disk space?
Are you attempting to install an illegal/cracked copy of Orcad?
Is Orcad 9.2 even compatible with Windows 8?
mishra87
Joined Jan 17, 2016
1,063
I restart my laptop and tried to install again but problem remain same.
Yes , I have 1 TB Hard disk
I have installation key of orCAD 9.2
Do can check with compatibility issue...!!!
bertus
Joined Apr 5, 2008
22,931
Is your operating system the same (32 of 64 bits) as the software to be installed?
Are the service packs for win 8 applied?
From the screenshot it looks like a permission failure.
mcgyvr
Joined Oct 15, 2009
5,394
Does orcad 9.2 is compatible with windows 8
Just a little help on your English..
It should be "Is orcad 9.2 compatible with Windows 8? "
The "Is" and the "?" are important..
And from what I found 9.2 is only compatible with Windows 7 and earlier versions.
It is not compatible with Windows 8.
