optocoupler output current
alan70
Joined Oct 31, 2021
19
With the circuit shown can someone tell me, and show derivation of, the output current the optocoupler can support?
I am only interested in circuit as shown and do not need variations or suggestions on how to change it.
The KB814 is being driven to saturation and is acting as switch to control the 12V supply to the relay.
Thanks in advance for any help given
DickCappels
Joined Aug 21, 2008
10,661
Check the coupler’s data sheet says about CTR (current transfer ratio).
The current the collector-emitter can provide is >= LED current x CTR
Papabravo
Joined Feb 24, 2006
22,111
The CTR (Current Transfer Ratio) is not likely to be a well controlled parameter of the device and it wiil degrade over time. Over a period of several years it may go from an initial value to maybe 10% of tha original value.
alan70
Joined Oct 31, 2021
19
My understanding is that linear relationship where CTR = Ic/If only holds in unsatuarted region and that it breaks down in opto saturated region. Graph below (not for KB814) shows this.
Papabravo
Joined Feb 24, 2006
22,111
Linear on a log scale is not really linear. CTR definitely gets worse as you increase the LED current beyond the nominal testing point which is usually 10 mA. Here is a typical simulation of CTR for a fairly "hot" version of the PC817
35,190
Ironically, opening post was already flawed in the first place.
BobTPH
Joined Jun 5, 2013
11,656
Have posted amended diagram to first post.
Don’t do that! You invalidated all of the comments that were made about your original post. If you make a correction to a pist that has already been discussed, make it inly in a new post.
I found the thread very confusing when I first read it after the edit.
28,332
Looking at the corrected circuit and the copy in post #15, a crude approximation is 12.5 mA for the relay and about 12 mA for the LED assuming it is a red LED, and assuming that the transistor in the opto-isolator reaches full saturation. The exact numbers will be a bit less, probably.
alan70
Joined Oct 31, 2021
19
What I don't know is if the opto at suturation can support that output current. On some sites I have read you should, for a saturated opto, use its lowest CTR value, which here is 20%. The forward current through the opto is 21mA. 20% of 21mA would only support a collector current of about 4mA.
35,190
As noted by the member in post #16, you must not edit the post because it negates the discussion that follows it.
The original post has been restored.
AnalogKid
Joined Aug 1, 2013
12,280
Using the minimum CTR as a design point is good practice, as that is the value the device can hold as the internal components age. And, your math is correct. 20% is a relatively poor CTR for an optocoupler these days. If you are stuck with that part number, the solution is a driver transistor between the opto and the relay.
ak
