Hello Circuits Community.
I am trying to design an AC detection using optocoupler and have been having trouble and thought to reach out for help to the community.
I am inputting 120 VAC via diode (S1M-13-F ) to the optocoupler (LTV-814S-TA1 ) and want the logic on the output to switch between 0V and 3.3V, however, I see output go from 3.3V to 2V when AC is high, so essentially don't pull all the way down.
At 18k @ 120 VAC, should get 6.6mA
At 1k @ 3.3 VDC, should get 3.3mA (which I might be exceeding per datasheet)
Are my resistor values are off and what would values should be?
Also, are my values sufficient for long term operation of 5 years?
Thank you for your suggestions and comments.
