Opto Coupler 817 not switching off
abuhafss
Joined Aug 17, 2010
318
Hi
Here is the schematic on which I am working:
Without the sensor, the circuit works fine with direct 220VAC. However, when sensor is introduced the opto-coupler remains ON even when the sensor is off.
Diodes 1N4007
4 x 150k resistors in parallel so resistor value is 37k.
Coupler is PC817.
Sensor is 2-wire inductive. I also tried photo sensor with same results.
(Please ignore the GND sign in the schematic).
Alec_t
Joined Sep 17, 2013
15,158
Presumably the sensor (or its mounting) provides a conduction path even when it is 'off'. Can you post a link to the sensor?
Ian0
Joined Aug 7, 2020
13,298
If it is a two-wire sensor then it must provide a conduction path when off, otherwise, where would it get its own power from?
abuhafss
Joined Aug 17, 2010
318
Additional information:
If I connect an LED + resistor + 9V battery at the output of the coupler, the LED lights brightly when the sensor is ON and gets dimmed slightly when the sensor is OFF.
abuhafss
Joined Aug 17, 2010
318
Since the 2 wires of the sensor have no polarity, they can be connected either way.
The lower-right is the 1st pin of the opto coupler.
The LED is disabled.
I have tried different AC sensors, all have same results.
sghioto
Joined Dec 31, 2017
8,756
From the brochure from Rico it says a maximum residual voltage of 10 volts.
Might try increasing the value of the 37K resistor.
abuhafss
Joined Aug 17, 2010
318
I increased to 2 x 330K = 165K, no change.
In fact, the test load LED is more brighter when sensor is off. Difficult to visualize the change in LED when sensor is OFF/ON.
sghioto
Joined Dec 31, 2017
8,756
Did you measure the voltage across the zener when the sensor is OFF?
Show the schematic of how the LED is connected to the PC817.
Ian0
Joined Aug 7, 2020
13,298
If you get the quiescent current from the datasheet, you will be able to work out the value you need, instead of faffing about substituting values until you randomly might get it to work.
