hi e17,
Try this cut down sim.
I guess you realise that you will not get uF capacitors at the tolerances you are calculating, typically they can be +/-10%, some as bad as 40%.
You should have a trim pot in series with the rtc fixed resistor so that you can set the frequency to suit the cap.
I will look at the timing within the CD4024B, let you know what I find.
Why don't you use a 3.2768kHz xtal for the 4060 and follow it with a CD4013 for a 1 sec pulse.
I have read the other thread, could you summarise exactly what you are trying to do.?
E
E
