This is what I came up with so far, a gain of about 28. In class, the only purpose of using the darlington pair was to give a high gain. and the hand calculations showed that there was a differential gain of around 5000 V/V for a problem that has the same setup as the attached circuit. can you explain why I get such a fair gain in here, and how to make it better?
