Open ended USB interface
Wendy
Joined Mar 24, 2008
23,869
This comes close to the spam restriction, but I think it will pass muster. Just came across an interesting gadget, wish I could afford it (later perhaps). Basically it takes a USB port on your computer and expand it out to several channels of digital inputs and outputs, similar to what the printer port is often used for.
http://www.bgmicro.com/index.asp?PageAction=VIEWPROD&ProdID=12926&HS=1
I can see so many uses for this gadget...
Wendy
Joined Mar 24, 2008
23,869
Have you looked at my blog? :) I put that particular microcontroller up there because I thought it was neat. The thing of it is, I used to write assembly code, but I burned out on it. I'd rather have a quick and dirty interface to use with a high level language. If I ever get back into that mode I'll probably check out the Ardunio controller.
There have been several times I wanted a simple interface for BASIC to control something else. The printer port is good, but it is fading away, so a USB alternative is also good.
