The input to the circuit is current source fed through coaxial cable , can anyone explain me how output is calculated, Thanks in advance
The FCT in is the input source, the fast transformer current output is carried through coaxial cable from field.Where is the current source? Where is the coaxial cable?
Noninverting opamp AC performance | PCB Layout , EDA & Simulations | 17 | |
OpAmps in parallel | General Electronics Chat | 21 | |
Opamp gain-of-5 stability resistor | General Electronics Chat | 26 | |
Correct means to lower/set input impedance of parallel opamp inputs? | Analog & Mixed-Signal Design | 12 | |
Opamp gain calculation | Homework Help | 22 |
