OPAMP not gaining up the signal
Engineer_tech
Joined Sep 19, 2014
31
HI
i have an opamp (opa211) setted up in non inverting configuration with R2(feedback) resistor value as 100k and R1 as 1K. I need a gain of around 100.
Applying a signal to the input of the Amp i am not able to get an amplified signal at the output.The output i am getting is little bit amplified version of the input.Apparently i have rechecked the connections, i don't see any loose wire or bad connection.i am not sure what the problem could be.
I have attached the pin configuration Diagram for OPa211.
Here is the details of the input i Applied to the Amp.
V+=10V
V-=-10V
In+=sine wave 500mV p-p
In- =grounded
please comment
Thanks
ericgibbs
Joined Jan 29, 2010
21,497
hi Eng,
I make that a gain of 101, so a 0.5Vppk would require an output swing of ~50 Vppk !!!
E
EDIT:
Whats the Vin frequency?
38,595
Double check all your connections and component values.
Do you have the power supply's common point connected to ground?
Post a compete circuit diagram.
Engineer_tech
Joined Sep 19, 2014
31
Thank you all i figured it out actually the op amp was damaged i replaced it with a new one and now i can get an amplified version of the input signal.
This is such a nice knowledge sharing platform.i thank all the contributors for making it a very nice learning platform.
Regards,
Ali
