Opamp Inverting Amplifier Design & Simulation using LT Spice
mishra87
Joined Jan 17, 2016
1,063
Hi Guys,
I have been associated with this fourm from more than 4 years.
I want to contribute vedio lecture to this so how I upload the same in fourm.
Audioguru again
Joined Oct 21, 2019
6,826
Why are you posting your video here? Is You Tube paying you for each view?
The audio sound is bad due to your broken English, severe accent and strong echoes.
mishra87
Joined Jan 17, 2016
1,063
No, Nobody is paying for me.
It is just for may be some people can learn something in electronics.
I am not professional YouTuber or Vedio Grapher.
Audioguru again
Joined Oct 21, 2019
6,826
I wonder why I do not post a You Tube video on a forum in your country using your language that I cannot speak, with strong echoes in the background?
Probably your video would be better on a forum in your country using your language and without echoes.
DickCappels
Joined Aug 21, 2008
10,662
Personal remark: The content of the video is fine. The fact that some people have difficulty with the accent does not detract from the quality and usefulness of the lecture.
danadak
Joined Mar 10, 2018
4,057
You start the video with no background, such as today we will discuss Operational
Amplifiers. Our analysis of Feedback will be the results of approximations, eg. We
do not consider effects of Aol on the G equations for example.
In your simulation C2 and C3 are irrelevant because they are in parallel
with V sources, which have 0 ohm impedance. But in actual application they
are needed because V sources in actual application are not ideal with 0 ohm
Impedance.
Your definition of R-R is not quite right. R-R means input and output voltages
can approach the supply rail voltages and still have the opamp in its linear
region. Older technology opamps could not do that, such as LM709, LM741,
LM324 (it could do one rail, not the other).
You call out CMRR as 90 V, should be 90 DB
You discuss drive 30 mA but do not mention that will not be at R-R output
Voltage spec
So far you do not describe what these specs mean, so does that mean
your audience is advanced ? That the video is a review ?
Your 100 ohm .1 u output filter has a 3 db BW of 16 Khz. Is that intentional ?
You should discuss this as a consideration.....
Regards, Dana.
Audioguru again
Joined Oct 21, 2019
6,826
On TV when somebody has a strong accent they print subtitles as the translation on the screen.
Playing this video over and over, near the beginning it sounds like he wrongly says that the opamp inputs are the enverting transmitter and the non-enverting transmitter. Also, instead of saying "feedback" I do not know what he said.
In my city there are many new taxi and truck drivers who talk like in this video and an electronic surplus store (Sayal) from India where all the staff talk like him except without the echoes.
