Opamp Compataror Oscillation Problem
ilginsarican
Joined Jul 13, 2017
147
I use this circuit below to compare different voltages.
When these two voltage equals, opamp output oscillates(I measured "A" point)
I used 1000uf capacitor, oscillation has decreased but not completely.
How can I solve this problem?
danadak
Joined Mar 10, 2018
4,057
In schematic no C on OpAmp supply pin, Should have a Tant and a .1 uF ceramic.
Cap selection (not all caps for same value equal ESR performance) -
Regards, Dana.
12,132
The opamp probably is not oscillating. When the two input voltages are close, the opamp is acting as a linear amplifier, boosting the input signal noise by about 25,000 and presenting it to the output.
This is a relatively low gain opamp, so it will take more than the usual amount of hysteresis to calm it down.
ilginsarican
Joined Jul 13, 2017
147
I use LM324 and TLC271.
