Opamp Circuits design,analog, fan control
alimutlu1
Joined Aug 4, 2017
23
I found this circuit that below to use control my cooling fan. When the temparature exceed 90 degrees, the mosfet must conduct. I am not sure it will work or not. Can anybody help me analyze this circuit?
DickCappels
Joined Aug 21, 2008
10,661
Yes, we can help you analyze the circuit. It will probably work but you might want to use a pot instead of R23 and R62 so you can adjust the threshold, that is because it is unlikely that you will have the same thermistor as was used in the original design.
What do you want to know about it?
dl324
Joined Mar 30, 2015
18,465
You're using a non-standard symbol for the fan switch, but should be an N MOSFET for low side switching and looks like P.
The bottom left opamp is unnecessary.
Sensacell
Joined Jun 19, 2012
3,787
The entire lower left branch circuit can be replaced with 2 R's and a C.
The circuit might chatter and misbehave when the temp hovers near the threshold, I would add hysteresis to make it 'snap' on and off.
Ylli
Joined Nov 13, 2015
1,092
You guys do realize this is a PWM temp control, right? The lower op amp creates a pseudo-triangular waveform that is compared to the voltage from the thermistor to create a variable duty cycle signal feeding the gate of the MOSFET. A little hysteresis in the upper right op amp might be a good idea
The fan is not just on and off, it is speed controlled by temperature.
AnalogKid
Joined Aug 1, 2013
12,273
There are two ways to control a small cooling fan. These are the basic descriptions, not complete in every detail.
1. On/Off : Above 90 degrees, fan runs full speed. Below 90 degrees, fan is completely stopped.
2. Proportional: Above a minimum temperature (for example, 80 degrees), fan starts running at a slow speed. As the temperature increases, the fan speed increases. At some higher temperature (for example, 100 degrees) the fan is running at full speed.
Which way describes what you want to do?
ak
Sensacell
Joined Jun 19, 2012
3,787
I stand corrected. It's funny how the way schematics are drawn can lead you astray.
alimutlu1
Joined Aug 4, 2017
23
ak
ak
Actually, my target is that achive proportional control. But my circuit it is only work when the temparature higher than 90 degrees. I have idea about right comparator opamp will control mosfet just conduct or not. But in this circuit I do not know how to run it in full and slow speed. In addition mosfet is ZXMN6A09DN8 in this circuits.
38,812
From my simulation of the sawtooth generator, the output from the comparator to the fan MOSFET is off until the voltage from the thermistor circuit is about 2.5V.
Thus you want to select the value of resistor from the thermistor to ground (presently 22k) to give 2.5V @ 90 degrees.
What is the resistance of the thermistor at 90 degrees?
