LTspice IV:Stability of Opamp Circuits
hoyyoth
Joined Mar 21, 2020
531
Dear Team,
I am studying about the stability of opamp circuits using LT-spice with the help of this video. But the explanation is not clear to me.
I have couple of questions regarding this.
  1. For checking the gain peaking the loop is not broken.Why Phase margin is not available from that gain peaking plot.
  2. For finding the PM the loop is broken and a source is placed with DC=0 and AC=1.Why?
  3. what will happen instead of DC=0 if I provide some other value like DC=5V
  4. Can I break the loop anywhere
  5. Is there any method to test the stability without breaking the loop
  6. In both cases (gain peaking and PM) the input source is made as zero,why
Regards
Hari
hoyyoth
Joined Mar 21, 2020
531
The circuit I posted (the simulation file)is the one which I need to test the stability.The image what you see in my question is taken from the video file.
LvW
Joined Jun 13, 2013
2,037
Two supplementary comments to post #6:
* For a second-order allpole system we can find a direct relation between phase margin and closed-loop peaking (see, for example, Sergio Franco: "Design with Operational Amplifiers Analog Integrated Circuits")
* There is a relatively new method to test stability and derive the corresponding phase margin without breaking the loop.
The principle: Injection of additional phase shift values into the closed loop and analysis of the corresponding closed-loop phase function.
LvW
Joined Jun 13, 2013
2,037
Dear Team,
Regards
Hari
Hari - I have answered all 6 questions in "Electrical Engineering" forum (in response to your question).
sparky 1
Joined Nov 3, 2018
1,218
To break or not to break, different methods have been proposed.
apparently, there are some discrepancies but are close approximations.
The math behind them must be very close.
Those who measured them in the past must have been fairly close.
Overcoming the obstacle of not breaking the loop in LTspice.
Frank Wiedmann - Loop Gain Simulation (google.com)
zip file "loop gain probe"
