Read this.
R2 and R3 are there to have a symetric signal at the output.
When you tie pin 3 to ground, you will only get the positive parts of the signal.
I can not read the number of the opamp.
It is unlikely that an opamp can drive a speaker.
For driving a speaker you will need more power.
Will Below ckt work with MCU ADC.
MIC_OUT out signal
How can be reduce jitters or noise ???
Bertus
Read this.
| Thread starter | Similar threads | Forum | Replies | Date |
Noninverting opamp AC performance | PCB Layout , EDA & Simulations | 17 | |
OpAmps in parallel | General Electronics Chat | 21 | |
Opamp gain-of-5 stability resistor | General Electronics Chat | 26 | |
Correct means to lower/set input impedance of parallel opamp inputs? | Analog & Mixed-Signal Design | 12 | |
Opamp gain calculation | Homework Help | 22 |
