opamp as a comparator
SgtWookie
Joined Jul 17, 2007
22,230
could you advice me some complementary mosfets?
You would probably be better off to use two identical N-ch MOSFETs and a high-side driver IC.
It could also be made to work with N and P channel MOSFETs, but an integrated driver IC would certainly make things easier.
But, you haven't given any particulars so far about what kind of power output you're expecting.
[eta]
OK, 5W output, way back in the beginning of the thread.
What are you going to use for an inductor?
baggio2
Joined Dec 25, 2008
60
i am going to use 60uH...but my circuit was designed according to N channel and p channel mosfet...i wanna change only mosfets...i need complementary N and P channel mosfets
baggio2
Joined Dec 25, 2008
60
thank you bertus but in the board mosfets are separated...so i need two different mosfets but they must be complementary
beenthere
Joined Apr 20, 2004
15,819
If they need to be complimentary, choose IRF520 and IRF9520, or IRF530 and IRF9530. In both cases, the 5XX device is N channel, while the 95XX device is P channel.
