DickCappels
- Joined Aug 21, 2008
- 10,661
I did not see any power supply bypass capacitor in your circuit. I woul install that before going any further.
Hi! I haven't tried using bipolar, I don't have much experience with them, also the plan was to use the transistors at around 120V so finding such high voltage bjts would be difficult i believe.Ok so did you try a bipolar instead of mosfet yet? The circuits end up more stable.
hi! my power supply is through a boost converter which does have output capacitors (I haven't mentioned that in my schematic, my bad), also i checked the power supply output during operation, it stays stableI did not see any power supply bypass capacitor in your circuit. I woul install that before going any further.
I'll try it if I can find them, thanks!Maybe the input should be a shielded audio cable and the shield will prevent the input from picking up the output and prevent other interference.
i'll try that thank you!Like said - right near the chips, and high quality ceramic capacitors, not just large electrolytic capacitors.
Im surprised nobody suggested that before thisLike said - right near the chips, and high quality ceramic capacitors, not just large electrolytic capacitors.
