It was a hall effect sensor. PN: UGN3503. V1 refers to the output of the hall effect sensor. The distance of the magnet from the sensor was varied to produce those measurements.hi 34,
What are the details of the sensor used on the test.?
E
The results shown in the V1 column in the original post is from the output of the Hall sensor.hi,
What results do measure when using Hall device as an input.?
The Hall Vout is ~ +1.5V thru +3V
Note the load impedance marked on the data sheet.
E
Is because you are gaining up the CM voltage. If it was a real differential amp it wouldThanks for your help Dana. Although i'm still not sure why it's clipping.
Yes it may be unequal, the input of this circuit was from a sensor.
