Op amp in inverting voltage follower configuration
ecaits
Joined Jan 6, 2014
56
I want to use op-amp as a voltage follower configuration and positive dc voltage signal is applied to inverting terminal.
So I should get same negative dc voltage on output.
Which circuit I need to use??
38,829
"Inverting voltage follower" is a contradiction in terms.
I believe you mean an inverting amp with a gain of (minus) one, which Dick's circuit will do.
ecaits
Joined Jan 6, 2014
56
Hi Zapper,
Yes same thing which is require to do.
Please can you post the circuit.
ecaits
Joined Jan 6, 2014
56
From your description, I think you are looking for this circuit. To make the gain 1:1 make Rin = Rf
Hi DickCappels,
Same thing I have already tried by simulator but not getting the expected output.
Input DC voltage range is 300 mV to 800 mV and I have require -300 mV to -800 mV as output.
I am using LMP7721 op-amp in my circuit.
Can you please provide the +/- Vcc voltage...
DickCappels
Joined Aug 21, 2008
10,661
That looks like a very high-end opamp. To make it simple try ± 1.5 to 5 volts. You can make the resistors large, perhaps 100k if you don't need more than a couple hundred kHz bandwidth.
