Voltage at non inverting pin of op amp
alison_941
Joined Dec 21, 2022
18
Could anyone here confirm what will be the voltage at pin 3 of op amp for below schematic in terms of mathematical equation. I want to proof read my equation if its correct or not. my final equation is 0.6V+{(R7/R5)*I1*R4} ignoring offset voltage of opamp.
Thanks in advance
35,268
If the opamp is working correctly with negative feedback applied, the voltage on the non-inverting input will be the same as the voltage on the inverting input, otherwise the output of the opamp will reach one of the supply rails.
38,909
With negative feedback, the high open-loop gain of the op amp will always try to adjust the output voltage so as to make the voltage difference between the two inputs essentially 0V.
WBahn
Joined Mar 31, 2012
33,309
Thanks in advance
I'm assuming that Voffset1 is modeling the offset voltage of the opamp (that you are ignoring)?
Your result indicates that Vx (what I'm calling the voltage at the opamp inputs) depends on the value of R7 but does not depend on the value of R8.
Does that make sense?
Isn't the voltage you are looking for (Vx), taking Voffset1 to be 0 V, just going to be the 0.6 V plus the voltage drop across R5 (taking the current to be flowing left-to-right in R5)?
If so, then does it make sense for a larger value of R5 to result in a smaller difference between the 0.6 V input and Vx?
Draw an equivalent DC circuit with I1 and R4 converted to the Thevenin equivalent. I think you will see what needs to be done from there.
