I ran across this thread and thought I'd hijack it as it's so old but is very relevant to what i'm doing. Using a simple Dual D FF as indicated, using a Schmitt trigger with the "momentary on" pushbutton w/debouncing; I want to drive 2 sections of a 4066 quad bilateral switch for the switching of line level signals. Tho /Q is tacked to D. Can /Q be tapped also to a switch actuator of the 4066? Or would it be better using Master/Slave configuration? The purpose is to switch from one active signal path to another (A/B switch). This will be multiplied into a digital signal switching matrix for my guitar rig. Is there a particular Dual D FF IC that would be recommended? Will the Schmitt give sufficient "edge" to toggle? I would prefer to have leading edge vs trailing for timing reasons.
It's been a long time away from design work, so forgive my ignorance or "thickness".
