On Inductance
kdillinger
Joined Jul 26, 2009
141
I have a quick question regarding inductance. If I were to ask you the question, "What is the inductance of this piece of wire?" what would your answer be?
It has been an awful long time since college, but is there not an assumption in this question? How can a wire have inductance when no loop is defined? No loop --> no surface area to integrate over. Said, Sir Maxwell.
I would presume once you have the return path (loop) defined, then you can start to calculate partial inductance of wires and PCB traces in circuit. THAT I am sure is another topic.
alfacliff
Joined Dec 13, 2013
2,458
strieght wire has inductance too. it dosnt have to be coiled. ever hear of "stray inductance"? why does wire have no surface area?
kdillinger
Joined Jul 26, 2009
141
You used the words "partial inductance". Read more on that topic and you will find out how the lack of a loop is dealt with.
http://en.wikipedia.org/wiki/Partial_element_equivalent_circuit
http://web.mst.edu/~jfan/slides/Archambeault3.pdf
I found a few PowerPoints by Dr. Archambeault. It is my understanding that a loop (or return path) must be defined first and then from that partial inductance can be calculated.
My question arises from discussions PCB traces where a person wants to know the inductance of a PCB track based solely on a given length. It's not that simple, and all the 'inductance calculators' one may find online are assuming *something*; I presume that *something* is a defined loop, path, closed surface.
alfacliff
Joined Dec 13, 2013
2,458
what you are calling a loop is a completed crcuit. inductance is related to length of inductor, and the shape of the path. a streight path has inductance. a single turn coil has close to the same inductance as a piece of wire the same length as the coil. a multi turn coil has more inductance due to coupling of the individual turns than the length of wire. coils are made on printed circuits too, usually in the shape of a spiral or zigzag path. any ferous or non ferous material in the field of the coil also affects the inductance. ferous, iron and such, increase the inductance, and non ferous, brass and aluminum decrease the inductance.
38,506
Inductance has no practical meaning if there is no current in the inductor. So, yes, there has to be a path for the current. But that's also true for the calculation of resistance and capacitance of a line. Do you somehow feel that inductance is different? It's not.
kdillinger
Joined Jul 26, 2009
141
http://www.comsol.com/blogs/computing-the-inductance-of-a-wire/
So, let's expound a little bit. The inductance for a piece of of wire is, from what I see, calculated based on an ideal case: the wire exists in free space with no other current carrying conductors close by and the surface is bounded.
But this becomes far more complex in a real application like a PCB where one will have ground planes, VCC planes, and other current carrying conductors. To simply say "I have a PCB track that is 20 mils long, so the inductance of this trace is X" would be incorrect.
Lestraveled
Joined May 19, 2014
1,946
When you start talking about the traces on a PCB, you are moving away from simple inductance and into transmission lines. A PCB trace has length, width, a dialectic and most often a ground plane. Now you have to consider wavelength and frequency content. Are PCB traces where you are headed?
kdillinger
Joined Jul 26, 2009
141
Yes. This is an exercise of 'thinking out loud'. The conversation starts out with a piece of wire as if that is equivalent to a PCB trace.
BR-549
Joined Sep 22, 2013
4,931
Inductance always has its' twin with it. If the circuit is steady, they will be sleeping. If the potential changes, capacitance will wake up. If the current changes, inductance will wake up. When the current changes, that changes the potential, and wakes more capacitance, which changes the current, which then wakes up more inductance. weeeeuuuuu. One loop?
One loop, one dual entity like in
http://en.wikipedia.org/wiki/Jefimenko's_equations#Discussion
It's not new physics, just a different way of looking at things.
alfacliff
Joined Dec 13, 2013
2,458
why all the fuss? wire has inductance., pc traces have inductance. pictures of either dont. you can make up thought games all day long and all you will do is confuse people, is that the purpose of this?
kdillinger
Joined Jul 26, 2009
141
OK. Are you ready to transition from the idealistic world of a single wire in space, to a trace on a PCB??
As long as you don't tell me that the only thing you need to know is the length of the track. :cool:
Let me summarize your post:
"A wire has inductance."
"Why?"
"It just does."
You, sir, are not helpful. At all.:rolleyes:
