On and Off Delay Relay Circuit
kymera
Joined Dec 4, 2023
19
The schematic is correct but the mosfet doesn't look installed correctly on the breadboard.
Online schematic shows, when looking at its face; pins are 1-Drain 2-Gate 3-Source from left to right. Drain pin goes to relay pin and Source pin goes to Ground. Is this configuration correct?
sghioto
Joined Dec 31, 2017
8,756
Appears then the mosfet is shorted. Install the mosfet correctly and connect the gate directly to ground to confirm if it's shorted.
kymera
Joined Dec 4, 2023
19
Is there anything I can do about it ? I just bought it new today. Also did any of my wirings cause this? I want to learn to avoid further mistakes.
sghioto
Joined Dec 31, 2017
8,756
Not if it's shorted.
Possible it was bad when you bought it. Where did you get it from?
Do you have any BC337 transistors on hand? If so can try the other circuits.
kymera
Joined Dec 4, 2023
19
There is only one component store in my city and I will let him know of the bad mosfet. I want to build the other circuit but I don't have BAT54 diode and the exact 12.1k and 11k resistors at hand. Can i substitute them with 1N4007 and resistors with similar values?
sghioto
Joined Dec 31, 2017
8,756
It works! Current open time is around 5 secs and I will increase it with a higher capacitor. However, relay closes right away when I cut off the power.View attachment 328229
Of course you killed the power.
:D
To simulate when the ignition is ON or OFF remove the diode or install a series switch.
With this circuit I was getting about 5 seconds both ON and OFF.
kymera
Joined Dec 4, 2023
19
Hi guys, me again
I just made the circuit and it works beautifully when powered on. However it shuts off almost immediately after the power is removed. I used as much as 2000 mF capacitor but Off Delay seems to be indifferent. Can I use a resistor to limit the power drainage of capacitor to elongate the off time?
sghioto
Joined Dec 31, 2017
8,756
I don't think you wired the switch correctly.
This is a test circuit and the switch is wired to only simulate the Ignition ON and OFF.
12 volts is maintained on the collector of Q1 constantly.
Look again at the schematic below.
The circuit in the vehicle will look like this:
kymera
Joined Dec 4, 2023
19
You came to the rescue again! Thank you, I will modify it accordingly.
