MisterBill2
- Joined Jan 23, 2018
- 28,279
Those 2 diodes are certainly Zeners, at least one has a 1N 7xx number. So that is why adding the bypass caps is so very needed.those diodes could be zeners to reduce voltage to 7815 we need a schematic.
Yes a schematic would be great, but many hours of searching and talking to some pinball companies, there just aren’t any to be had. (Since this game is a “home” unit there wasn’t much importance placed on schematics, I’m told)those diodes could be zeners to reduce voltage to 7815 we need a schematic.
No it's 28V AC from the Transformer according to the circuit diagram on the manual, making it 28V DC , then smoothing capacitor boosting it to around 39 V..If it helps, We seem to have 56vdc coming in.. so it must be loosing up to 26Vdc across the three devices... ( I don't think the reg will stand much more than 30Vdc..
Post #23..Yes a schematic would be great, but many hours of searching and talking to some pinball companies, there just aren’t any to be had. (Since this game is a “home” unit there wasn’t much importance placed on schematics, I’m told)
Would you mind detailing that just a bit more? I’m a “tinkerer-jackleg” that has had good luck on some repairs with simple knowledge...some things are a little vague for me and I need a bit more detailed “how to”...ONCE AGAIN, the regulator really MUST have the bypass capacitors to avoid oscillation. That may be why the circuit failed in the first place. A couple of the cheap 0.1 mfd capacitors right across the regulator terminals. You see them in every application note about power tab regulators. Just because they were not part of the original does not mean that they can be left out. Not every game designer is willing to do things right!
It's 5.6 Ohms #23In case no one has said this yet:
1.0 to 9.1 ohms, 5%, 1/2 W, carbon composition.
And it may have already been covered by you guys but...the middle leg of that 7815 runs into a thick trace that runs along he edge of the boardside (looks like a wirewound 1K 7812TRWPW5 10% resistor has a leg tied into it with the other going to the big 2200mf 50V cap, continuing on up to the topside to the second lug of an edge card connector...(I’ve read that these have a couple or so bridge rectifiers up in the main machine box near the power supply that are underperformers and should be replaced...?)Still can’t sleep and looking at this board (cross-eyed about now)...
Those two diodes to the right of the sink and bad resistor have the label of “IN4733” on them...
The middle leg of a 7815 regulator is the negative terminal, and so the trace it is tied to is the supply negative, probably the common. Looking at the front of the power tab regulator the lead to the left is the supply and the lead to the right is the regulated +15 output.And it may have already been covered by you guys but...the middle leg of that 7815 runs into a thick trace that runs along he edge of the boardside (looks like a wirewound 1K 7812TRWPW5 10% resistor has a leg tied into it with the other going to the big 2200mf 50V cap, continuing on up to the topside to the second lug of an edge card connector...(I’ve read that these have a couple or so bridge rectifiers up in the main machine box near the power supply that are underperformers and should be replaced...?)
