- Joined Jan 23, 2018
- 28,283
What the 2 drawings show is the external to board wiring, which may allow you to trace the circuit and see if the individual items function, and draw only the correct current. So that may be useful if the problem is a failed outside part. Otherwise you will need the circuit of the PCB to see just what is causing the problem. One option could be to replace the resistor with a much higher value one, 2.2K ohms would limit the current a whole lot, and that would probably enable tracking the source of the high current draw.
