Ohms law??
Hotfingers
Joined Mar 29, 2015
2
Hi I'm new to this site and would be grateful for a bit help with some home work exam to follow shortly...if I have the resistance and the csa how do I work out the length?... Thanks guys
32,848
Cross sectional area PB. I guess we talkin wire diameters. My answer would be find the equations that use these known measurements and substitute where required.
R=(resistivity x length) / csa
So to use that equation you need three of the four parameters. You apparently only have two. You also need to know the resistivity. Doesn't it make sense that the length of aluminum wire is going to different than length of copper or the length of steel?
@Hotfingers : Do you have either the resistivity or at least the material that the wire is made out of?
22,082
I missed the part about aluminum. Where did that come from?
Nevermind, it was just an example to show different materials have different resitivity.
Treeman
Joined May 22, 2014
157
Treeman was being helpful as much as he could. I assumed there was more info to reveal - this seems to be the case often.
32,848
No problem there. I didn't realize until after I had posted that the two quotes in my response were from different people, so I went back and added the note to the TS.
