Ohms law calculations questions and answers
Train tech
Joined Mar 10, 2024
9
I’m looking for some good ohms law based calculations work sheets. With the answers. I’m looking for both series and parallel questions. Im looking for calculation questions rather than principles, which a lot of work sheets are based on from what I’ve found.
35,183
Think circuits.
Currents flow in circuits through conductors. In other words, a conductor conducts current.
On the other hand, resistance resists the flow of current.
Resistance is the inverse of conductance.
If we give mathematical symbols to resistance as R and conductance as G,
then
R = 1/G
or inversely
G = 1/R
When resistors are connected in series, the resistance add. In other words, the total resistance is the sum of each individual resistance.
When resistors are connected in parallel, the conductance add. In other words, the total conductance is the sum of each individual conductance. Since current has more paths to flow, conductance increases.
