Octave pedal boosting bass instead of dividing wave
rfpd
Joined Jul 6, 2016
101
I managed to 'clean' the square wave, but after the hype of it working, only now I figured out it was just boosting the bass... I mean it makes sense, since it has three low pass filters with a cutoff frequency of 159 Hz. I mean, before the filters I get a fuzzy sound, so I think it's not bypassing it. Can someone tell me how's this happening?
btw the flip flop is powered by 9V and the first opamp is powered and biased with 9 V aswell, just used 10V because there isn't a 9V opamp in the simulator.
rfpd
Joined Jul 6, 2016
101
In the flip flop I only connected Vcc, Vss, and the connections made in the schematic. I didn't connect the rest to ground, could that have anything to do with it?
Alec_t
Joined Sep 17, 2013
15,158
The 4013 is a CMOS circuit. You must NEVER leave unused inputs of CMOS circuits floating (unconnected), or you can get weird results.
rfpd
Joined Jul 6, 2016
101
Yeah I think that was it, I used this schematic now, but after the filters I still get some squary noise, I mean if I play carefully I don't hear it as much (still bothers though), isn't there a way to filter it?
rfpd
Joined Jul 6, 2016
101
Btw should I connect everything else to ground aswell? Like Q1 and -Q1 (not being used, only Q2 and -Q2)?
35,249
How would you like it if someone stuck a rag in your mouth? That is what you are doing if you ground Q1 and /Q1.
Never connect output pins to GND or Vcc, or Vss or Vdd.
Alec_t
Joined Sep 17, 2013
15,158
Connecting an output to ground is a bit like plugging a shorting bar into a mains socket! Sparks will fly, or the magic smoke will escape.
