octave simulation in ltspice
ntetlow
Joined Jul 12, 2019
71
For my pains I have been working through examples in radioshack 200 in 1 science fair projects.. Number 180 being an octave generator (file attached).
There are three octaves involved, labelled high, medium and low in the simulation with wire attached in turn to the resistors next to the npn transistor. Sampling the output at label out2, I have created a .wav file for each of the three states all of which work perfectly. At label out, after the transistor amplifier the sampled octaves do not give a useful .wav filjust a mere blip sound.
Does anyone know why this should be, the waveforms in ltspice look identical?
ericgibbs
Joined Jan 29, 2010
21,561
hi,
Try this, change the .wave command
the 'out' must be V(out).
Use your own JK F/F I used a 4027 for test.
Wave file sound works OK now.
E
ericgibbs
Joined Jan 29, 2010
21,561
hi,
I have always been advised to have the V(xxx), as it now works OK, no problem.:)
E
Do you have the free Audacity download, great program for audio work..
