NUCLEO-STM32F767ZI no ST-LINK detected problem
Status
Not open for further replies.
zazas321
Joined Nov 29, 2015
936
I have just purchased STM32 nucleo board F767ZI. I have generated cubeMX project and opened it using Keil uVision. I have used all default settings for projects and connected the board to my PC using USB. I am not able to debug/program the board as the internal st-link is not detected. Can someone give me a hand and advice me what to check and look for to solve this problem?
Picture of my board:
Target setinngs:
Debug settings:
ST link pcb schematic:
zazas321
Joined Nov 29, 2015
936
Yeah I see now. That could be a problem:
If i try to automatically search for a driver update it fails:
I guess I will have to look up where can I download ST-Link Debug drivers manually.
Thanks !
zazas321
Joined Nov 29, 2015
936
Hey. I am able to flash the code now. However, I am unsure whether it does not let me use debug_printf function to print some message to the output. I have always been using this debug_printf when using Jlink to debug. This is the first time I am using integrated st link. Is st link not capable of handling debug_printf messages?
alfecjo
Joined Apr 17, 2022
Acabei de comprar a placa nucleo STM32 F767ZI. Eu gerei o projeto cubeMX e o abri usando Keil uVision. Eu usei todas as configurações padrão para projetos e conectei a placa ao meu PC usando USB. Não consigo depurar/programar a placa porque o st-link interno não é detectado. Alguém pode me dar uma mão e me aconselhar o que verificar e procurar para resolver esse problema?
Imagem da minha placa:
Configurações de destino:
Configurações de depuração:
Esquema da placa de circuitos ST link:
Tive o mesmo problema, contudo, no meu caso a placa nao reconhecia porque o cabo usb que estava usando serve apenas para alimentacao e nao para dados. assim que troquei o cabo, passou a reconhecer...1650240520849.png
35,081
Google translate:
I had the same problem, however, in my case the card did not recognize because the usb cable I was using is only for power and not for data. As soon as I changed the cable, it started to recognize...
Status
