NTC termistor in serial/paralel
racmaster
Joined Feb 13, 2018
59
i have 2 very basic digital thermostats from ebay using NTC probe cable temperature sensor. i want them both to share 1 temperature sensor, how should i connect those 2 cables? paralel - just split cables to both thermostats, or serial - 1 sensor cable to 1st pin of thermostatA, 2nd sensor cable to 2nd pin of thermostatB and connect 2nd pin of thermostatA with 1st pin of thermostatB?
thank you
thermostat: https://www.ebay.com/itm/W1209WK-DC...hash=item41d602e8e6:m:mw1MV1_4W_PvYIjRc4g2G5w
Dodgydave
Joined Jun 22, 2012
11,395
Tie both sensors together and then they'll both read the same temperature .
Do you want to read one temperature with two separate displays?
