NPN Output to Operate Relay
TaskMaster
Joined May 14, 2018
I have a machine (lathe) with NPN outputs for a robot interface and the robot being used has PNP inputs/outputs. Attached are the drawings for my lathe interface. Could anyone assist with how I'd drive a relay using signal Y3.5 (lower portion, second sheet, E32)? I'm also not clear on the "COMG" signal if anyone can help clarify.
Thanks much!
MaxHeadRoom
Joined Jul 18, 2013
30,684
I will double check the Fanuc 0i connection manual, but I would assume COMG is Common(GND).
It would appear the output contact for Y3.5 switch to 0v as shown.
Max.
MaxHeadRoom
Joined Jul 18, 2013
30,684
Unfortunately the manual does not offer alot of help regarding the robot I/O.
I skimmed through section 9 that covers I/O but did not reveal much, you may get something from it if you don't already have.
p.s. it is over 10Mb so if you need it send me email add via P.M.
Max.
TaskMaster
Joined May 14, 2018
Thanks very much, Ill shoot you my email.
Is there a minimum post count or other restriction to send PM/start conversation?
