Thanks for the suggestion! Fortunately, for my immediate case, each skeleton has just 3 AAAs to power the light in the skull, so I should be good, but I'll keep your note in mind for the future. Cheersif the B1,B2,B3 voltage are same or similar, circuit from post #6 will work well enough.
the thing is that LEDs normally do not handle well reverse polarity. many of them can only tolerate couple of volts (5-6V). so if one of the batteries is much higher that then the others, then there will be an LED or two that will be stressed or possibly damaged (for example B1=9V, B2=6V, B3 = 24).
since B3-B2=18V and B3-B1=13V, both of which are greater than usual 5-6V max reverse voltage for LEDs, diodes LED1 and LED2 would be operating out of spec and likely get damaged. if the B3 circuit did not exist, difference B1-B2 is only 3V which is ok so LED1 and LED2 would be ok and no protection is needed.
to prevent issues due to significant voltage discrepancy one can use multi-pole switch or add regular diodes in series with batteries.
