I am sorry 50 KhzThe ATmega328P operates at 16MHz max.
I wondered about that too.I am sorry 50 Khz
Even the lowly CD4069 can easily do that.I am sorry 50 Khz
it is generated using arduino for power converterI wondered about that too.
Why can't you invert with software? How is the square wave (PWM?) being generated. What is it synced to?
is 7404 suitable ?Even the lowly CD4069 can easily do that.
So? Why not do it in software? Are you writing the code or just cut and paste?it is generated using arduino for power converter
yes this is thae case, i want to generate a square wave with its complementaryTaking a guess; do you need 2 signals out of phase with each other and that's why you want an inverter? It may be easier to just use 2 IO pins and invert one.
Unfortunately , I am not a great coder. I looked for libraries to help but without any resultsSo? Why not do it in software? Are you writing the code or just cut and paste?
7404 is an order of magnitude faster than CD4069; it uses more power too.is 7404 suitable ?
Yes. any version of a 7404 or 7414 that is rated to operate on 5 V will work.is 7404 suitable ?
Are you considering a "dead time" so both mosfets (?) are not on at the same time. That can be done in software, or there are chips that take a single PWM input and output complementary signals with deadtime.yes this is thae case, i want to generate a square wave with its complementary
Thread starter | Similar threads | Forum | Replies | Date |
K | RS232 Framing Errors | Programming & Languages | 4 | |
L | Control logic for Mosfet | Power Electronics | 5 | |
L | Question about a control logic needed to be implemented | Homework Help | 15 | |
Y | understanding logic of level shifter | PCB Layout , EDA & Simulations | 12 | |
L | Propagation delays in control lines and potential bus contention | Digital Design | 6 |
by Aaron Carman
by Aaron Carman
by Jake Hertz
