Not getting proper voltage
outstandingpotential
Joined Jun 19, 2019
5
When measuring the terminals with a meter I am getting 3 volts. I am getting 1.5 V from each battery bank, but I am not getting the 9V I should. When I connect the motor directly to a 9V battery everything works. l cleaned the corrosion on the terminals as well. See attached pictures.
MOD:Improved your images.E
ericgibbs
Joined Jan 29, 2010
21,575
hi op,
Welcome to AAC.
What voltage do you measure on the output terminals when only two batteries are in the holder [ say the two at one end].??
E
ericgibbs
Joined Jan 29, 2010
21,575
hi,
Reason for doing that test is that it maybe a battery holder that connects 3 pairs of 1.5V in parallel, giving 3V out with a higher current rating.
It is hard to tell in the photo how the batteries are linked in the holder.
E
KeithWalker
Joined Jul 10, 2017
3,619
Do a bit of simple troubleshooting. Using your first illustration as a guide, connect the positive probe of your voltmeter to the positive end of the top cell (on the right). Then in sequence, with the negative probe, measure the voltage on each end of each battery, starting with the negative end of the top battery, then the positive of the second battery down (which should indicate the same as the last measurement), then the negative end of the second battery. Continue down until you have measured on each end of every battery with respect to the positive end of the top battery..This will indicate if you have a continuity problem in the battery holder and where it is.
Joined Jun 19, 2019
5
Do a bit of simple troubleshooting. Using your first illustration as a guide, connect the positive probe of your voltmeter to the positive end of the top cell (on the right). Then in sequence, with the negative probe, measure the voltage on each end of each battery, starting with the negative end of the top battery, then the negative of the second battery down (which should indicate the same as the last measurement), then the positive end of the second battery. Continue down until you have measured on each end of every battery with respect to the positive end of the top battery..This will indicate if you have a continuity problem in the battery holder and where it is.
I have done this already. Voltage measures the same for each bank. So my best bet is to replace the battery terminals or just use a 9V battery holder?
The connections behind the batteries inside your device may not be wired in series. You may want to look at the circuit board.... rather than just the individual batteries.
djsfantasi
Joined Apr 11, 2010
9,237
Perform a continuity check between each pair of springs on one side of the holder. No batteries should be in the holder. Just check continuity
  • Between the bottom and middle springs
  • Between the middle and top springs
  • Between the top and bottom springs
And report your results.
KeithWalker
Joined Jul 10, 2017
3,619
No, you have not done what I suggested. You have measured each battery separately. Read what I wrote again and try what I suggested, keeping the negative probe of the voltmeter in the same place all the time. The first two measurements should be the voltage across the top battery. The third and fourth measurements should be the sum of the voltages of the top two batteries, etc. This will tell you exactly where the problem is..
