That's because the input impedance of the amp is most likely less than 10K. I would go with the 1K pots if you need better control of the volume.While I was testing the 50k that worked, it would be at a fairly low volume until completely maxed out.
Not if it's an amplified subwoofer.to line in a Subwoofer I'd need to give away one of the outputs.
I think I will add another controled volume output and plug in the subwoofer from my edifier P3060s. That or just use the headphone output lolNot if it's an amplified subwoofer.
That would work as there is a volume control on the sub.That or just use the headphone output lol
You mentioned output power.
The datasheet of the PAM8610 amplifier shows 15W per channel but with horrible clipping distortion of 20% (1% sounds fairly bad) when its power supply is 15V and the volume is turned up way too much. Using your 12V supply, its maximum output per channel will be 6W to 7W with reasonably low distortion.
