Non zero output from LM358 even though input is zero
Arbitrage
Joined May 3, 2021
17
Hi
I was using LM358 as voltage comparator in non inverting configuration
I gave 5V to vcc and 2.5V to inverting pin through a potentiometer
The issue is I am getting a output voltage of approx 3.8V even when the supply to the non inverting terminal is zero
I get output no matter I set the voltage of the non inverting pin zero or less than or more than that of inverting terminal
Also the ic gives the same output when non inverting is given some voltage and inverting is zero
The ic output gets zero only when both inverting and non inverting terminals are zero
Please help me to sort this
I desire to get high output only when the voltage at non inverting is greater than that at inverting i.e 2.5V
dl324
Joined Mar 30, 2015
18,523
What was the voltage at the non-inverting input?
Are you expecting this high output to be VCC? Why are you using an opamp as a comparator? In addition to being slow, the output can never reach the positive rail. A comparator, such as LM393, would be a better choice.
Papabravo
Joined Feb 24, 2006
22,116
Nowhere is it written that ANY opamp will output 0 Volts, for a 0 volt input. There is a value in the datasheet called the "Input Offset Voltage" which tells you the approximate differential input voltage to get a 0 volt output. Consult any textbook on operational amplifiers for an in-depth discussion.
DickCappels
Joined Aug 21, 2008
10,661
The opamp seems to be working normally. 3.8 volts is about right for a "logic high" on the output of an LM358.
When the inverting (-) input is lower than the non-inverting(+) input the output will be the highest voltage the device can deliver (3.8V).
When the inverting (-) input is higher than the non-inverting (+) input the output will be the lowest voltage the device can deliver (0.2V)
If you need a comparator, the LM393 is a dual comparator that has the same pin-outs and the LM358 but it is designed to switch quickly between states. It also has an open collector output that can, with for example 1k load resistor going to +5V swing almost all the way to +5V provided you don't load it down too much.
Arbitrage
Joined May 3, 2021
17
The signal voltage to be given at non inverting is around 4V
I was using opamp to reduce the need for pullup resistor at output
dl324
Joined Mar 30, 2015
18,523
That's outside of the allowed input voltage range. You should read the datasheet.
The maximum guaranteed output voltage is 3V from the positive supply, 2V in your case. Typical is 2V from the positive rail.
Saving a resistor isn't going to get you what you want.
EDIT: For a heavy load, the guaranteed high output voltage is 4V from the positive supply. 1V in your case.
ericgibbs
Joined Jan 29, 2010
21,649
hi Arb,
If you have an Hi impedance DVM , measure across the +IN and -IN pins of the LM393, post what you measure. Be sure to set the +IN to 0V .
E
Arbitrage
Joined May 3, 2021
17
I replaced the opamp with LM393
The issue is when I test the comparator individually ,it works fine, i.e it will give output only when noninverting is greater than inverterting
But when I connect it in the whole circuit the same issue occurs of giving output when noninverting is zero
PLEASE HELP ME TO SORT IT
The four comparators marked in the circuit have issue
Arbitrage
Joined May 3, 2021
17
actu
I assume you mean when Pin #3 of SL1 is zero volts, because Pin #4 is connected to 0v.?
Check my LTSpice drawing is correct..
You are not showing any power rail decoupling capacitors or the LM393 power pins.?
E
actually in eagle this was the only symbol available without power pins, I have given 5v to vcc pin
Arbitrage
Joined May 3, 2021
17
E
Pin 4 was also reading same 0.01 even after connecting to ground rail
ericgibbs
Joined Jan 29, 2010
21,649
hi,
Are they on the actual circuit.
Post a photo of the project.
E
AnalogKid
Joined Aug 1, 2013
12,298
There is a GND symbol to the left of IC2A that probably should be connected to the bottom of pot R2, but is floating without a connection dot.
There MUST be capacitors on both the inputs and outputs of each voltage regulator. There should be decoupling capacitors close to the power pins of each IC.
Are any of the four circuits working correctly?
ak
