AD620 simple connection with no input but the output never close to zero
waseem3
Joined Sep 9, 2023
11
Hi all kindly need some advice regarding this :
am using ad620 amp to work with EMG signal, am using 4 AAA batteries as a source and the circuits as in the attached image.
so as I understand the ground would be the point at the middle of the 4 batteries so I get the +3v / -3v for the AD620, and I connect the refV to it.
so I suppose the output should be close to zero but it is not, the output is 3v or -3v, even if both inputs are floating. or with 1k ohm to ground.
I believe my source ground is somehow wrong, but I could not manage to know what is it or what to do.
thank you in advance.
waseem3
Joined Sep 9, 2023
11
I removed it just to make it look like the IRL circuit . here is it, it working fine in the simulator though.
I thought it could be damaged, i used another AD620 but same.
AlbertHall
Joined Jun 4, 2014
12,653
As the two amplifier inputs are connected together. The amplifier has an input offset voltage so the output will be the gain times that offset voltage but that should only be 500uV maximum.
Try connecting the inverting input to the output instead.
waseem3
Joined Sep 9, 2023
11
am really confused ..... is it damage ? I have 3 other AD620 to test ..... some question please :
- is this a good ground refrance ?
- can I connect the refV to +3v ?
ericgibbs
Joined Jan 29, 2010
21,567
Hi w,
As post #13 states, pin #5, Vref to 0v, which should be at the mid-connection of the two battery pairs.
Use your voltmeter to measure these voltages.
1. the +3v at the battery.
2. the -3v at the battery.
3. All the pins on the AD620
Post the voltages you measure.
E
waseem3
Joined Sep 9, 2023
11
Hi w,
E
Hi Ericgibbs
thanks to you and to crutschow for the replies.
I measured all the pins and the point between the 2 batteries pairs as a reference to all =0v :
pin1= 0v , pin2= 0v , pin3 =0v , pin4= -3v
pin5= 0v , pin6= +3 or-3v, pin7= +3, pin8= 0v
all as expected but the pin6 with the 3v output !
I test all other 4 AD620 ... same thing , do you recommend buying new AD620 or there is something I can try?
ericgibbs
Joined Jan 29, 2010
21,567
hi w,
I would suggest a quick test circuit.
Assume they are a standard OPA, say like the LM741, can you build a simple amplifier on your bread board.
Using the pins as though it is a LM741, then apply test input voltages, see what you get out on
The AD620's you have, maybe fakes, or defective.
E
waseem3
Joined Sep 9, 2023
11
hi w,
E
HI Eric
sadly it seems like you are right ..... fake (-_-)
Using LM741 as an example, I made a circuit where the feedback resistance is 1k and the input 10k so the gain is 0.1
and connecting the 2 offset ground, using another battery as inverter input, non-inverter to ground.
the output is -0.15v.
thanks a lot and sorry for the disturb X)
