Non-polar (bipolar) capacitor from two in-series polars
13hm13
Joined Jun 1, 2023
75
A 31-week lead time on Nichion MUSE 450uF non-polar capacitor (needed for speaker crossover) is unacceptable.
This long lead time at Mouser, DK, et. al.
I assume creating on non-polar 450uF from two in series 900uF polars is an option.
So:
---------- (pos) 900 uf (neg) -------------- (neg) 900 uf (pos) ----------
Equals:
---------- (NP) 450 uf (NP) -------------
Correct?
sagor
Joined Mar 10, 2019
1,055
Video still shows a polarized capacitor, with higher voltage rating and lower capacitance (1/2 of equal value caps).
Original poster's diagram is correct, joining same polarity in the middle, will give nonpolarized capacitor "equivalent" with 1/2 the value of two identical caps.
28,292
It is not likely to find a 900 mfd capacitor of any flavor. so use two 450 mfd in parallel in each direction as shown in the drawing.
And what sort of crossover requires that much capacitance???
Ian0
Joined Aug 7, 2020
13,279
In terms of distortion, damping factor and avoidance of clipping, it would be preferable to put the high pass filter on the input to the amplifier, not the output.
AlbertHall
Joined Jun 4, 2014
12,653
Given the likely tolerances available, two 1000uF caps in series will do the job.
