Noisy HC-05
spinnaker
Joined Oct 29, 2009
7,830
Seeing this on the transmit out pin of an HC-05.
It seems to be enough to trigger the receive interrupt flag on my scope,
Far worse if I am sending data to the device. P,S, I have not changed the time base here.
Has anyone seen this anything I can do about it otther than replacing the HC-05?
dl324
Joined Mar 30, 2015
18,340
Do you have adequate power supply decoupling?
I was searching for a problem in an LED cube I'm prototyping. I thought it was timing or cross-talk pickup from long wires. After days of troubleshooting, I found out it was supply decoupling. I had stuck an electrolytic and a couple ceramic caps I had handy and that wasn't sufficient.
That was the first time I ever had a problem with power supply decoupling. But the cathode drivers can switch up to 300mA.
spinnaker
Joined Oct 29, 2009
7,830
I would hope it would have its own on board circuitry. But you might be on to something. I I raise the supply voltage the noise ratio becomes less and less.
What would you recommend for decoupling?
P.S. Power is currently being supplied by by bench supply.
I have never seen this issue before. Always worked out of the box.
