I would hope it would have its own on board circuitry. But you might be on to something. I I raise the supply voltage the noise ratio becomes less and less.Do you have adequate power supply decoupling?
I was searching for a problem in an LED cube I'm prototyping. I thought it was timing or cross-talk pickup from long wires. After days of troubleshooting, I found out it was supply decoupling. I had stuck an electrolytic and a couple ceramic caps I had handy and that wasn't sufficient.
That was the first time I ever had a problem with power supply decoupling. But the cathode drivers can switch up to 300mA.
I use whatever's handy. An electrolytic in the 100-470uF range and ceramic 0.01 or 0.1uF.What would you recommend for decoupling?
| Thread starter | Similar threads | Forum | Replies | Date |
| R | Noisy Electronic environment | Off-Topic | 4 | |
extremely noisy signal | Homework Help | 19 | |
| X | HI-FI system noisy fan. | Technical Repair | 24 | |
Measuring shunt voltage in very noisy environment (read welder) | Analog & Mixed-Signal Design | 24 | |
Are Metallized Resistors Noisy? | Analog & Mixed-Signal Design | 20 |
