HelloCause and effect ?
I'd suggest not to use a noise DCDC in this case,
or if you do , you need to filter its output well, may be using a low noise LDO,
Explain more about LDO.
The characteristics of the filter depend heavily on what kind of signal (the spectrum of the signal) that you want to get through. You have not yet mentioned what signals you want to receive.(some text removed for clarity)
I need frequencies less than 2.2 MHz.
What filter do you suggest?
HelloThe characteristics of the filter depend heavily on what kind of signal (the spectrum of the signal) that you want to get through. You have not yet mentioned what signals you want to receive.
Since 2 MHz is very close to the frequency of your noise source, you will probably have an easier time just lowering the amount of noise coupling into the amplifier rather than trying to filter it out. So, I would concentrate on layout and decoupling for now.Hello
I need frequencies below 2 MHz
