Hi!
I have a mic + an amplifier which I'm connecting to a computer and measure sound through Audacity.
When I started, without any filter, I had a lot of noise, which can be seen in one of the images attached. But then I applied a lot of low pass filters.
Most of the noise is gone but there is still a very high peak around 9000 Hz, see image attached, and I don't know why ...
Does anyone have an idea? It's not removed even if I filter after the amplifier.
I power everything with a switching supply, a power bank.
Could it be due to a bad connection somewhere, bad grounding, wires, computer? Help me brainstorming, or better, you might know exactly what causes the peak.
Thank you!
Thank you!
