Noise Filter-MATLAB SIMULINK
bertus
Joined Apr 5, 2008
22,998
I can not download the file.
I get the following message: You should Sign Up or Login to download this file
I do NOT want to join the site, just to download a file.
bertus
Joined Apr 5, 2008
22,998
I did have a look at the file and found the following info.
When you look at the last 5 seconds, you will see that all noise is above 8500 Hz.
When you look somewhere in the middle of the file the noise is also visible above this 8500 Hz.
You could try to make a filter that will remove the frequecnies above 8500 Hz.
I do not have any experience with matlab, so yopu will have to look into it yourself.
