noise circuit pickup
ultraboto
Joined Feb 29, 2024
Hello
I am work in lab and we have a lot of noise sources that sometimes screw with measurement.
In order to find the noise source, i want to build a circuit with an antenna to pick up the locations where the noises are more strong. I am thinking in something very simple like this:
Is this enough? Its just an antenna with a high pass filter ( the values, are not correct, i need to calculate something that filter low frequency that its not important to me! Of course i need also a antenna that operates in the region i want, put this i can buy.
Thanks in regards!
35,245
I encountered the same issue in a research lab many years ago.
I made a coil from magnet wire, about 10-20 turns of about 24-28 AWG wire on a 1cm diameter cardboard tube.
Then I connected the coil to the input of a portable oscilloscope and went hunting.
I found the problem to be an errant computer with a bad power supply. I asked the owner to replace the computer and the problem was resolved.
ultraboto
Joined Feb 29, 2024
thank you!!
BobTPH
Joined Jun 5, 2013
11,662
What a great use for a portable scope!
