Nodal Analysis
gjoef
Joined Aug 16, 2012
1
may i use your help.. i cant answer this circuit.. resistor 1 has 2ohms, resistor 3 has 3ohms, resistor 4 has 6ohms and resistor 2 has 2 ohms.. the voltage source on top has 10V while the voltage source adjacent to resistor 3 has 12V.. may i see your solution using nodal analysis here.. please..
33,187
No.
But if you post your attempt we will be more than happy to help you identify any mistakes you have made and/or confirm the parts you have done correctly.
Also, did you forget something? Hint: What about the current source on the extreme left?
