Hi again,Hey!
i am not sure that at node b the direction for the R3 resistor will be entering or leaving and i am not able to finde the node c equation and i used nodal analysis to do it.
I think it would be more exact if we say that the main reason for Vc not needed to be a node equation because it is not a principle node - a node where three or more wires meet.So does that mean you're not going to post what you got and how you did it?
In that case I'll show this extract from a Maple worksheet showing the two node equations for Va & Vb. Vc does not need a node equation since the voltage at Node C is a constant.
