No vibrato on silver face vibrochamp
Skylar Coy
Joined Apr 29, 2017
133
Hey, this is a silver face champ model aa764. It has no vibrato. the voltage on the plate of the vibrato tube (bottom one on schematic) is 170 which is far too low. I have replaced all electrolytics and most other caps in the thing. No other components look burnt. This model should not need the pedal for the vibrato to be on or am i just dumb? thanks! i have the proper 340 volts coming from the power supply also. its happening between the power supply and the tubevibrochamp-schematic.jpg
#12
Joined Nov 30, 2010
18,224
There is nothing but a wire from the 340 VDC at the capacitor to the pin 6 plate, but the voltages are different, therefore you have a problem with the alleged wire. Albert also has a point. Are you measuring in the right places?
Skylar Coy
Joined Apr 29, 2017
133
On which pin of that valve are you measuring 170V - 1 or 6?
Pin 1: .68v
Pin 2: .88v
Pin3: 0v
Pin4: 0
Pin5 : 0
(Those two are connected)
Pin 6: 369
Pin7: .7
Pin 8: 9
Pin 9: 0
That 170v reading must've been a fluke
Could that 470k resistor be at fault
#12
Joined Nov 30, 2010
18,224
Twist the speed knob back and forth while watching the DC on pin 7. That will tell you if the DC is leaking out through the 0.02 capacitor. The answer should be, "zero changes". If the speed knob changes the DC, you have a bad capacitor.
Skylar Coy
Joined Apr 29, 2017
133
Nope. No change.
Skylar Coy
Joined Apr 29, 2017
133
There ain't no, "after that" until you actually check it!
You are asking for crystal ball work. Try doing the real work.
I meant that because I don't wanna make 40 trips to the electronics store for each component. I have already replaced the 2x .01 caps and the .02 In the vibrato section
Skylar Coy
Joined Apr 29, 2017
133
You don't have to drive to the store to measure a resistor or pull the tube out of the socket to see if it's internally shorted.
Yep.
After that? That depends on the actual resistance of the supposed 470k.
Tested and it was wide open. Replaced with a good one. Now when I turn the vibrato knob up, it cuts volume. What the hell lol I'll compare voltages on pins soon.
